clutching 136
00sxrjoe
Maine
Little sled back ground. Sx 700 136 1 3/4 power Inc pipes 147 mains 45 pilots I know it needs 47.5 has high idle hang. Clutches 40-10s 15.6 red spring may be weak. 4.5 heel 3.3 mid with rx1 8fv at 80* I can't seam to get that sled over 8200. Ditch banging. Should I leave it or pull weight to get to 8700. It will pick up some rpm on trail.
Well went to a 45/41 and it brought it up to 8500. Then it falls back to 8100.
They will be coming back off they are thirsty. Rode 80 miles and used 7/8 of tank
That's basically mountain max clutching. I found that i couldn't run an rx1 helix when I was trying to get my mountain max clutched. The rx1 helix wouldn't back shift to keep the rpm's up in deep snow but it would be fine on the trail. If you have a 45 it might be good for now but a 43 will make sure it's in the power when you hammer it
Thanks for input I'll have to play around with it some more.
