Tim@DBF
Are brass spindle bushings that are in the front bulkhead replaceable? If so where do I get them from???
Yamaha Nutz
As far as i remember there are no spindle bushings on these sleds just a metal spindle tube
Tim@DBF
I have a lot of play between the spindle and the bulkhead! It's hard to tell if there's a bushing in there or not. I have it apart and it's really hard to tell if there is some sort of insert pressed in the bulkhead?
NorthofSixty
Can you post a pic. No bushing on the SS. Play is usually in the steering linkage and spring mounting brackets and not much in the spindles unless they were never greased. Sometimes the steering column bushings are worn as well.
Tim@DBF
I will try to get a pic posted next week. I have some play in the lower column bushing. The steering linkage is good otherwise. I am comparing it to my 85 with 1500 miles. This sled has 5000 miles. Want to try to tighten it up somehow.
