I wrecked a trailing arm and bought a pair of lightly used ones as replacements, little did I know they are not all the same...
The new arms is marked "R" so they probably belongs to an SXR?
My sled is a 2000 SRX, everything is stock apart from a SXR skid installed by previous owner.
If I buy steering rods, radius rods and swaybars from a SXR, will everything bolt up fine with the SRX shocks or do I need replacements?
I was planning to do the "shockmount flip" when I switch the arms, maybe that is enough to make up for the difference in angle between the arms without changing rods etc?
Or should I just buy another trailing arm that fits right on?
shaggyzr2
Those will fit the srx, not much difference between the two.
