drew24
Looks good. Do you have any pics of the skid after powder coating?
Will soon
I bought the wiring harness and CDI for it dirt cheap. It was a no brainer.
super1c
Super Moderator
Looks awesome Tom!
Thank you Chris. Will post pics of the skid when I get the sled back. I should have it back in a week or so.
It runs very good too and has a fresh top end. I'm going to run it with good fuel with a splash of Torco each fill up for cheap insurance. Next rebuild I want to have the cylinders and heads grinded on.
Ronquillo
That looks awesome, how much does it cost to get this done?
I picked up the wiring harness, cdi, and water rail on here for cheap.
I see u grass race I'm looking to grass race 500 foot track with my 02 srx it has 01 jetting and transfer rods thunder clutch kit 144 1.325 studs and rest is stock also gunna snow drag 660 want to figure out gearing and clutch weights
I have a 02 srx it's jetted to 01 spec stock gearing and a thunder shift kit has 144 1.325 studs hauk can I wanna grass drag 500 feet and snow drag 660 I need to figure out gears and weights for drags
What's best weights to run on my thundershift 02 srx and gears for 500 foot drag grass and snow
Looking to race my 02 srx has thunder shift kit wanna know what gears and weights to run for 500 feet grass
My racing days are long over. I just had both my hips replaced last fall. I used a 19/40 combo for 500 feet with 8bu 00 weights 20/40 would work too depending on what's in your clutches
I would start with a 20/39 for 660.
My buddy had a piped and lightened up viper. He would always be able to run a little taller gearing because the viper is lighter than the SRX.
did you have to go with 8 tooth drivers for 1.35 inch studs? Thats a pretty tall stud and was wondering about clearance issues. If you have 8 tooth drivers, that changes everything.
