which loctite to use on secondary bushings
I use sleeve retainer. I have had a number of them come out when I didn't use it.
Does anyone have a picture they can post of what is being talked about here? I feel like I'm going to be doing this soon.
It's the bushings that are pressed into the clutch themselves that ride on the shaft.. putting a lock-tight on the outside of the busching before you press it into the clutch helps keep it from coming loose. It's just green Loctite
Sent from my SM-G930R4 using Tapatalk
