2004yamahaviper
Just wondering where the best spot to find some 89L weights?
They came stock in a 1993 Exciter ST.
There are a couple 89L's on ebay, around 40 to 45 a pop though ...
Cheaper online
Yamahapartshouse.com
Weight Comp
89L-17605-00-00
Your Price: $36.06
Cheaper online
Weight Comp
89L-17605-00-00
Your Price: $36.06
2004yamahaviper
Thanks any way to tell which weights are on my sled in the yamaha parts look up there are 5 different weights. Just bought a used set of bender triples for it trying to see if I should change out to 89l or if my weights are all right and just need more rivet weight.
Existing set up is
2000 venture 700
Reed spacers
Exhaust mod will now be bender triples
Rx1 helix
Stock Springs primary and secondary
Added rivets to weights
1 inch hacksaw
For Agrissive trail riding
Existing set up is
2000 venture 700
Reed spacers
Rx1 helix
1 inch hacksaw
You should have 8ch/13.9 & 17.2
There are setups out there that use the 8CH weights for the bender pipes
I will see what I can find for you.
There is a setup in the tech section, under user setups.
One guy is using 8CH weights on a 1998 XTC 700 with SLP triple pipes.
Check it out, gives all the specs.
2004yamahaviper
put a set of 8 cr weights in er , they are a fairly aggressive weight and pull really well with that motor!
2004yamahaviper
I'll see if I can get my hands on a set thanks
