Kramer660r
Above the left footwell are two relays. Is the headlight relay the right or left one? My headlights are stuck on hi beam and switch does nothing. Thanks for the help.
I would look at the switch itself first. Sounds like it's not doing its job.
the white relay is the load control relay, the blue relay is for the headlights.
Kramer660r
Thank you both for your replies.
