norwegian Well-known member Joined Nov 5, 2004 Messages 2,904 Age 45 Location norway Mar 18, 2017 #1 Hi I can only get Ski-doo Yellow can oil for my sleds. Is it ok to use that oil on them?
norwegian Well-known member Joined Nov 5, 2004 Messages 2,904 Age 45 Location norway Mar 18, 2017 #2 Also found Ipone snowrace 2 oil. Will that work? Do I have to adjust my oil pump because I am switching to another oil?
A couple of bucks VIP Member Joined Jan 17, 2009 Messages 6,386 Age 59 Location Ogle County Illinois USA Mar 19, 2017 #3 If the pour point is substantial different, I'd say yes.
norwegian Well-known member Joined Nov 5, 2004 Messages 2,904 Age 45 Location norway Mar 20, 2017 #4 Ok, the shop manual says 22+/- 1 mm. Still with it at 23 mm, it wouldn't help much? Should I go beyond this?
A couple of bucks VIP Member Joined Jan 17, 2009 Messages 6,386 Age 59 Location Ogle County Illinois USA Mar 20, 2017 #5 You'll need exact fuel and oil consumption to figure correctly. Here's the calculator I used. http://www.totallyamaha.net/forums/showthread.php/70243-oil-pump-gap-23-5-mm?highlight=calculator
