What's the difference between these sprockets?
norwegian
Well-known member
norway
2001 MM 700 sprocket 89J-17682-10-00
2002 SRX 700 sprocket 8DW-17682-10-00
To the naked eye, there seems to be no difference. Both are made for a 13 plate chain.
both 21 tooth. Can I use either MM or srx chain on these?
the mm and 00-02 srx used different types of chain so the gears are different. srx and viper use the borg warner chain, all others used the rexnord chain.
I would say that the MM sprocket is a silent chain type because the 00-02 SRX use the HYVO chain and sprocket setup.You can't mix and match them,you'll need the whole setup with chain and both upper and lower gears.
I got a set of srx chain and sprockets in my mm and it is much louder than the stock set up.
