Jlc84cam350
Had shaky idling problems with my 04 sx viper and decided to take the carbs off for cleaning. When i did i found 2 problems,
1- center carb had a striped fuel screw so i could not clean that section on that carb, dont think i can do anything about this unless someond has an idea?
2- the clutch side carb when i checked adjustment on the screw i noticed thei were may to many turns before the needle seated, like 4-5, when i took it out it was missing the littlile o-ring on the end. I thought this was my problem so i went at the dealer and baught a new o-ring. Installed it back in with washer and spring and noticed it was sitting alot deeper than the other 2 carbs fully seated, to the point where i can see the needle poping out from inside the boar... the carb on the mag side does not do this anybody know whats going on? I will try to take a picture to show you guys what i mean
