Advice installing pro action sx rear skid in 92 phazer ii
..SNAKEBIT..
NE IOWA
OE rear skid is junk, broke & cracked all over.
have a 98 SX rear skid I am going to install
any body done this, looking for mount locations ans advice
It should not be too hard of a job.I would put both skids side by side with the adjusters backed right off then push them against a wall or straight edge.Then look were the front axles are located in both. Measure or use a template off the sx for the centre and rear if they are the same.
Narrow the skid to fit the tunnel, moved the rear mount up and drill some holes,this is a sxr skid and it works really well
