WNR18
I have a 94 Phazer ST. 136 1.25. I have a DG pipe, 36 mm flat slides, Uni air pods , Boyseen reeds , new style secondary.  Sleds works well. Wanting a little more. Can the heads be shaved  a few thou to up the compression? How much clearance? Ride at 1500 ft. Okay with mixing a little lead.
			Yamaha Nutz
tried to replay to your pm but your inbox is full ......  yes you can cut the heads but really good fuel will have to be used i would personally leave them stock unless engine work is done, with a pipe alone 93 is required to be safe
			WNR18
Thanks for the reply and tip about my inbox
