SX700R Pipe Install
Jacobozy
Wisconsin
Hello, i was just wondering if anyone knows how the CPR Triple pipes exit the belly pan. I the sled just has the stock hole for the stock exhaust. do i just shove the 3 pipes in the pre-made hole? or do i cut it bigger?
You just push the outlets thru the rubber ring in the belly pan. I had a set on mine years back. Once they are put on correctly they should all exit that same hole.
