Looking to grass drag my sled 02 srx 500 foot what gearing should I use can I use 19/40 or 20/40 with stock sled besides thunder shift clutching
Woody255
what size drivers are you using?
Sled is all stock besides thunder shift clutching cus I want to trail it too
Woody255
With stock 9t drivers at 8500RPM, a 19/40 gives you a top speed of 86-87mph. 20/40 equals 91mph. 21/40 calculates to 96mph. With proper traction for grass, I'd be thinking 19/40. If you are running a stock track with trail studs, you will likely spin terribly out of the hole with that low of gearing, so you may be quicker to gear up a bit. The best way to tell is to try it for yourself.
On snow, and in 660' races I would be in the area of 21/39 or 21/40, depending on your setups and conditions.
Good luck with the races.
Is that with stock clutching thanks for help
Is that with the thunder shift clutching for 660
Woody255
No, those are just the top speeds for the 3 different gearing combinations I provided with the stock 9t 2.52" pitch drivers. Those speeds would be calculated with both clutches in full shift (not overdrive) at a 1:1 ratio as I understand. If you do a google search "snowmobile gear calculator" you will see several to choose from.
As long as it's rpm is 8500 that 660 set up snow will work ehh 21/40 21/39 I have a 1.25 rip saw with 144 1.325 studs and transfer rods and a growler can
