pete_man26
Hi Guys,
I tried searching to see if the pilots on the Mach Z 38mm carbs are the same as the SRX 33mm carbs but with no luck as I'm unsure of the pilot series. Based on the micro-fiche and some pictures I have found they look the same but I can't confirm.
Can someone confirm if I can use my 33mm pilots in my 38mm carbs or are they a different series?
Thanks!
Thanks!
Same style. PM sent!
YAMMIEGOD3:16
yep, i believe take same pilot. 3:16x (yammie tony)
