Would anyone have the specs on the primary spring (yellow / blue stripe) supplied in their kit? Free length, spring rate, preload, total force? I have a used one I want to try but have no clue on the specs. Thanks!
Srx007
Well to try to help you out I went on the bender website and found this, they don't seem to have your particular spring description, may have to call them
OEM YAMAHA SPRING
Blue/Yellow/Blue
59.00mm LONG
6.17mm WIRE DIAMETER
25/90 kg (55/198 lbs)
OEM YAMAHA SPRING
Blue/Yellow/Blue
59.00mm LONG
