Anyone ever run a SRX 700 without the power valves installed? Obviously still capping/sealing the PV holes off.....How would it run? I realize it would be down HP but curious if anyone has ever done it and how did the machine perform.
pete_man26
Not sure about not having them installed but I have heard of guys running them pinned back to be open all the time for a drag setup. You shouldn't be down on power at WOT as they were designed to increase the low end power. I wouldn't recommend trail riding like this.
To seal them though you would have to properly seal it in the cylinder at the point where the PV is at its open position.
u need to keep the power valve in the hole but bolt them open :-
YAMMIEGOD3:16
they have been run in open position and i have seen them blocked off . i don,t believe you can just omit them. 3:16x
