Oil Light SXR
sledders
Melrose MN
Found loose connection, connected & the oil level light comes on even W/ full tank. Removed sensor test good with multi-meter. Order new sensor, tests good(down position continuity, upside down open circuit.) Suspect ground wire to sensor shorted. Removed wire before connecter to sender and connected directly to ground, light comes on. Now what?
