Bender jetting sheet
Squatch
ID
Anyone have a copy of the bender jetting sheet? Picked up a set of used pipes, on the drive home I briefly rolled down my window and the sheet blew out. Can't find it in search.
Call Justin at Full Power Performance. He designed them. 716-699-6299
Search for Turk's Bender setup. There's probably a million and one responses from the late guru. Below are a few...
150 main jets
52.5 pilots
raise needles 1/2
89L weights with a 2.4 gram rivet
14.5 mm rollers
y-s-y primary spring
52/44 helix
green secondary spring at 70 wrap
Home elevation
52.5 pilots
150 main jets
raise needles 1/2
8cr weights with 4.5 gram rivets in both holes
54/44 helix with green secondary at 70 wrap.
high elevation
62.5 pilots
137.5 main jets
drop needles 1/2 from stock
8cr weights with 3.6 gram inner rivet & .8 gram in tip
green spring with stock 43 helix at 80 wrap
20/40ish gearing
150 mains straight across
50 pilots
Raise needles 1/2 right across
14.5 mm rollers
89L weights with 2.4 gram rivet
52/44 helix with stock secondary spring at 60 degree wrap.
