Helix part # decode... ?
Lasse
SWEDEN
Hi !
I need some Helix and Secondary spring part # decode help
Helix:
* 8BV-17604-10-00
* 8BV-17604-30-00
* 8BV-17604-50-00
* 8BV-17604-70-00
* 8BV-17604-90-00
Secondary spring:
* 90508-556A7-00
* 90508-556A2-00
* 90508-500B1-00
* 90508-536A9-00
What do you mean ?
The part numbers you referring to is not the same as the ones I asking about !
Helix:
* 8BV-17604-10-00
* 8BV-17604-30-00
* 8BV-17604-50-00
* 8BV-17604-70-00
* 8BV-17604-90-00
My appolgies. I did not READ it .. I feel like a real dumb azz now. Sorry. I assumed that were the same :( I have not seen these numbers before. The tech manuals only ref secondary springs and cam angles with the number in those charts. Where did you find them?
90=39
10=41
30=43
50=45
70=47
I believe that if there is not a zero(but probably a 1 in its place) it is one of the following:
1. A revision.
2. A second production run.
3. A design change.
IE.....a 31 is still a 43*.
