MountainMax
RE: bender Roller Rooster GenII question
Hey guys, my stock secondary would allow me to add or remove shims under the three small rear bolts to change the free width of the secondary which allowed me to tighten the belt deflection, I tried this now since I got my Bender secondary, but now they do nothing, I removed my secondary and found there are a bunch of washers beetween my shieves now, can I just remove one of them to make my belt ride higher???if so why did they do this????
With the roller rooster you move the secondary shives close together by removing shims. So...when belt gets worn remove a shim or 2.
MountainMax
so I can remove those three bolts/washwers completely behind my secondary now? I just put all new bolts there and bought both size sets of washers.
The bolts behind the secondary are no longer necessary. You can remove them.
MountainMax
Where can i find new shims (washers) as I need to shim it up as my new belts (tried3) all squeel......
