ontario sledder
will i need to removed the tunnel protectors to run a 1.38" track? thanks
2003 yamaha viper 700. not sure it makes a difference but i have a AD Boivin expert X skid
A couple of bucks
Shouldn't.
super1c
Super Moderator
I have found anything over a 1" lug they will rub. I would remove them if not planning on running studs. Otherwise you have to trim the lugs at the protectors, not worth it to me.
Vincent
Don't know if there's much difference between a Venture and a Viper tunnel, but I've racked up 5000kms on a 1.35 Cobra track with tunnel protectors in place. I'm sure the track rubs them when decelerating but in my case the track shows zero damage anywhere from it. That said, for this season I have plans to finally remove them.
