SRX crank removal
bmillikin
Iowa
I'm having trouble removing the crankshaft from the lower case. Is there something I'm missing that would be holding it in there?
I was able to knock it out once it sat out in cold garage for a couple days. Where should I look to see if the crank has been welded previously?
will be welded on the end of the lower wristpin boss on the weight of the crank
