Max lug height?
Sawyer36
Maine
What is the max lug height that I can put on my 00 sxr 700? I’d like to put a 1.25 ice attack or a similar prestudded track but want to be sure it isn’t going to rub on the cooler protector.
A 1.25 will rub but it’s a easy fix. If you want to run prestudded you obviously need the protectors. Just trim lugs where they meet the protectors and all set! A pair of tile nips or electrician dikes work awesome for a bit of lug trimming and it won’t bother the track a bit!
The little studs on the lugs won’t damage anything? I’m looking at a 1.25 ice attack track.
M
