Posts
1
I have a 98 SRX 700 with a 1.25 lug track. I was thinking of studding it soon but will have to ADD the front h/e protectors. Will I have enough clearance? Also, what are your opinions on running that track with studs? I like the safety of having studs and also the hook up on the hard pack roads etc... Any advice is much appreciated.
1
Posts
1
Can anybody give a brother some advice? Lol
Cutting it close,,,,,,,,, will have to run track tighter then I would.............
A couple of bucks
Have you looked into re-riveting them in. Have heard it's a big beotch to do.
Ok I see, didn’t realize you could run the track at different tightness levels. Thanks for advice.
No haven’t looked into the rivet but somebody did mention the screw type that goes right i is only about 3/8 wide so not sure if that would work...
pete_man26
I'm running 1.5 chisels right now with the stock drivers. It barely fits, light graze on the front heat exchangers and made some fairly large tunnel protectors so the track can barely balloon and hit the tunnel. Running the track really tight as well. This was being used for 500 foot drags though. I would not recommend it on a trail sled. I do have a 1" track with 1.175 megabites and without any protectors I got some slight rubbing from ballooning at WOT on the lake. Protectors are a must when running picks.
Yeah I will be riding 80% trail. Just wanted the studs for the icy turns and for the quicker stopping power.
Plus, every time we hit the hard packed roads my nephews ZRT 600 with studs has been leaving me in the dust! That’s just not right! Lol
Srx007
You could switch the stock 9 tooth drivers out for 8 tooth and put diff gears in the chain case to regain top end, if you are willing to go that far..
Thanks for the advice... Switching the drivers from stock to 8 tooth? Does this give me more clearance for the track and studs?
A couple of bucks
Roughly 3/4" depending on the manufacturer.
Post #34
https://totallyamaha.net/showthread...art-out?p=706715&highlight=drivers#post706715
Post #34
Post #34
Thanks for the info...Does this effect the performance both on bottom and top end?
Sounds like a lot of work too. Switching gears in the chain case.
A couple of bucks
It will increase your low end "snap" and decrease you top end mph. I'd personally leave the gears stock at 23/37. You are 80% trail riding and shouldn't be even close to topping out. At least you sure as phuck better not be topping out an SRX7 on the trails. 8 tooth drivers w/ stock gears of 23/37 will still only be a 1.86:1 ratio. Absolutely PLENTY of top end for trail riding. She won't be the lake rocket she was, but that isn't what your after.
Now having said that, if you do line up with someone, make it a 1/4 or 1/2 mile race. And invest in some Velcro.
A couple of bucks
Possibly a neck brace as well.
I really appreciate your advice. I think I’ll do just that. I don’t need to do 115! Lol. So I do need to switch to the 8 tooth to run the 1.25 lug with studs ? Or can I just leave as is and put tunnel protectors and heat exchanger protectors ?
A couple of bucks
Always run w/ protectors when studs are used. Or be ready for some damage if you run w/o them. And yes you'll need 8 tooth drivers if you want studs on your 1.25" track.
A couple of bucks
Where is Brighton?
Where is Brighton?
Brighton, Michigan It’s about 30 west of Detroit. We do most of our riding in Upper Michigan though.
Thanks for all your advice on this stud situation fellas , especially Couple of Bucks . I had the skid out and replaced hi-fax on my 96 VMax last year. I’m good with a wrench but not a mechanic. Is this gonna be a pretty straightforward job?
A couple of bucks
Common sense will get you through. As long as the drivers are out, replace the speedo side bearing.
I took my jackshaft and 8 tooth extros to my local Yamaha shop for him to press the 9t off and press the 8t on.
