RXMax
What markings or numbers are on the correct flywheel from the 2001 or newer SX-R, Venture, Mountain Max with dual bulb to be sure I am getting the correct one to put in my 99 case?
the 300watt one from the dual bulb sxr engine has 4 magnets on the outside (3 large and one short one), the 175 watt one only has 3 evenly spaced as does your srx one for 98-99
https://www.ebay.com/itm/2002-Yamah...ash=item282304add8:g:lwkAAOSwUEVYDrDf&vxp=mtr
this is the correct one, if you enlarge the pic, youll see the extra small magnet for the 3d ign system
RXMax
Thank you again! F4T374 looks to be the one!
