Mrvmaxxtc
Im new to this forum, I made this account because my gf has a 97 vmax, and I . I'm an cat guy. Anyways, does anyone know where the fuse box is located on this sled? And what are some other reasons the E-start couldnt be working ??
A couple of bucks
After checking the obvious, I'd look at the starter relay.
https://partstream.arinet.com/Mobil...BHYzNVX3nXd2jnI10N0fP0ZDWzanZZh-OpQmjeQ1.html
super1c
Super Moderator
If there is a fuse box it will be on the side of the battery. I dont believe they came with one. The only fuses you should have are the 2 on top of the starter relay, located next to battery. On top, side ect. If fuses are good and battery is good next move key all the way to start and hold. As holding in start position take a screwdriver and place it over the 2 nuts on top of the starter relay. Careful it will spark and arc a bit. If the sled turns over its a bad relay. Your just completing the connection with the screwdriver instead of the mechanical relay. If its not that just start tracing wiring and go from there. Post results and we will take it from there. Welcome to the site!!
