92 Exciter II 570 - TORS/Carb problem
kylekilbarger
OH
So long story short, I bought the sled mentioned in the post title and immediately could tell i had a carb issue. When i really open up the throttle it bogs down pretty hard, but eventually (around 3-5 seconds and a little throttle play later) it quits and runs great and sprints down the snow like I know this sled can do. Now these twin carbs need to be tuned evenly so i tightened the throttle stop screws completely and evenly backed them out a little less than what they were when i had problems. At first it seemed like it was running better but then it started to act up again in the same manner. Throttling up hills was difficult too like it was previously. I decided to tighten them a little more so I did. Still kinda doing the same crap. Does anyone happen to know the proper setting for the throttle stop/air screws? Or has anyone else had this problem and know what else it could be other than screws? I also read somewhere where someone had a similar issue, and they solved it by disconnecting the TORS wires from the carb and connecting them to each other?. Any input is appreciated. The snowy season here in central Ohio is upon me and I've been working diligently to try and get this machine running at its full potential (I really want to smoke my dads Indy haha). Thanks.
