I am debating on powder coating my pipes and not putting the covers back on what does everyone do
A couple of bucks
Something like this works well when sandwiched between the pipe and shield. It stops the rattling and helps retain heat within the pipe.
http://www.woodstoves-fireplaces.co...MIgK64y5-Q2AIVj7XACh0dxQekEAQYAiABEgIQ5_D_BwE
SRXChris
I just used gear clamps. After replacing all my donuts this year I noticed how much they rattled. They are tight now.
those heat shields are there to keep the pipe temp constant and therefore your engine performance constant. A cold pipe will lower rpm, you wont outthink the technology Yamaha put into the exhaust system on a srx, even the stock heavy muffler works better then aftermarket loud cans do. the best thing is to keep the exhaust stock on a srx unless a full mod race engine.
