Primary Sheave Bushing
j.e.1975
ontario, canada
I'm rebuilding my primary on my 04 Viper. I installed the new OEM sheave bushing and it's too tight. Won't even engage on the shaft. I removed the bushing and checked the size. By squeezing the bushing tight it's already undersized without even installing it. Has anyone experienced this. Has anyone had any experience with aftermarket bushings.
Unfortunately it's not getting squished. When I hold it closed and measure it before it's installed, it's already before too small.
It's small enough that all the coating would be removed. This is the second time for this problem. Once all the coating is gone it will start to bind if the conditions are right. I can't believe no one else has experienced this. I need someone to measure the primary shaft on comparable clutch.
