RXMax
are they ported differently? HP difference?
thanks!
thanks!
Yes little difference in porting ...hp not sure they do more
thanks!
8dn10 is different port timing, exhaust is more aggressive and a tad bit on the transfer ports as well. 98-99 (8dn-00) made peak at 8300rpm, the 2000-02 (8dn-10)made it at 8500rpm. Nothing wrong with the 8dn-00 cylinders they can be made to perform just as good with some porting.
RXMax
Are the heads better too? How much more HP Stock for stock 8DN-00 to 8DN-10 with Cylinders and heads?
Thanks!
Thanks!
Thanks!
the heads are a lot better off the 2000-02 then the 98-99 are, more compression and tighter squish. the 98-99 can be machined to be the same but are bigger cc dome and lower the compression stock. Like the cylinders they can be made to as good with a little machine work. Theres not a giant hp difference, the 98-99 was average at 137hp, the 2000-02 was average at 140hp. the 2000-02 also had the 3d ign. system and even though they didn't make bunch more hp the engine changes and the ign made them a lot more responsive and fun to ride.
YAMMIEGOD3:16
great info 3:16x (yammie tony)
