the right grams or close to it.
780srxgeorge
michign
its been a little bit cen's ben on here & dont know where to put it.got a 00 srx & putting 8bu's in it & the weights are 50.0 grams empty.should be 48.7? so i dont know what happen.looking on the tec pages should be around 54.9.soo looking at 4.5 in tip or 3.6 or 3.1-3.1 in each hole.
the amount of weight will be dictated by the spring force and roller sized used, so there is no right or wrong amount of grams, only if the tach reads correctly for peak rpm whatever that maybe.
this is true mr viper.i know its a touch & go w/ rollers & springs:o|.thanks again will have to set it up & go from there.;)!:letitsnow
