What are the 4 electronic components under the left knee panel of my 98 srx
Amanda11270
Mechanicsburg Pa
Im tracing down problems with my srx600, it makes no sense to me. My tach does not work (Ive traced all the wiring, made a new under the engine harness), I ordered a used tach off ebay (havent gotten it yet).
Also the TORS system switch at the carb is unplugged and the wires from the harness are plugged together, I cannot run the sled with the kill switch plugged in as it will only idle. As soon as you hit the throttle it dies with the kill switch plugged in at the bars. Is this TORS not bypassed right? Can someone tell me is the carb switch (tors) open or closed at idle, and when you throttle it?
Lastly what are the components by your left knee on the srx, CDI, voltage reg? But Ive got two more.
