kylekilbarger
i have a 1992 exciter and i decided to put an LED bar on it. Like an idiot i wired the positive to the yellow wire (high beam) and ground wire to the blue wire (supplies power to switch). i turned it on and m light bar had great illumination but, but it was on when my low beam was on, off when my high was on. i wired the positive to the low beam and nothing. took off the light bar and connected the wires back to normal setting and now there is NO light whatsoever from my headlight and my high beam indicator light is on no matter what. i touched the positive light bar wire to the blue and negative touched to yellow wire and light bar barely works. same if i touch negative wire to green wire. checked the bulb and its totally fine. opened up my light switch and seems clean as can be. no clue what to do
