blueblooded
So I noticed after I torqued my new head gasket down that I forgot to install the steel bushings that locate the head on the cylinders.I had to take the head off to insert bushings then retorqued head using same head gasket.Sled was never fired....is it ok to retorqued/reuse this head gasket or should I order a new one???? This is a viper 700....three piece head gasket....fiber metal fiber.
blueblooded
Crickets????? Lol
bluewho
Loon....woo wooo
A couple of bucks
Reuse
staggs65
It will be fine
yes, if you use copper gasket spray, I have reused up around 20 removals. New gaskets are overrated
super1c
Super Moderator
X2. Clean and copper spray
blueblooded
Ok thank you!!
