ontario sledder
looking for some advice to know if the base gasket is leaking or if the coolant pump is leaking
2003 Yamaha Viper 700
Thanks in advance
Thanks in advance
Srx007
Definitely not coolant pump, I would think it is either coming from the power valves or the exhaust donut that is between the header and pipe, Im leaning toward the 2nd choice based on your pics.
ontario sledder
I just changed the exhaust donut about a year and a half ago or so. i checked the power valves and they were all about the same as this picture
super1c
Super Moderator
Looks like splatter from leaky PV’s. There are o rings in there that go bad over time and cause a mess like this.
agreed, powervalves are leaking and causing that black sooty oil, you need new seals(on pv stem) and O-rings on cables.
