hereismylife
Primary clutch cracked.
What year primary works with the sled?
Thanks Joe
Thanks Joe
super1c
Super Moderator
Any proaction clutch as far as im aware. You will need your cover (depending on what year clutch you find. Early versions had the short covers and later years had the tall, if for your viper it has the tall cover I believe the SXR's also.) weights and rollers. Even the early four stroke sleds used the same primary just didnt have the e start holes on back for ring gear.
hereismylife
Thank you. It is for the sxr 700
