nick5oh
Had the infamous wire harness run through issue last season. Pulled it all out this year. Fixed the one and only yellow wire that was rubbed through shorting causing headlights and cluster to go dead. All other wires looked good. Fired the sled up just now and I have a 7 flash code. Is it possible I forgot to plug something in? Power valves sticking? I haven’t even rode it just idling in the garage checking it over before a ride this weekend hopefully
I have a manual. But it’s for a 2000, mines a 99. What should I check electrically or should I just crack open the pv’s and make sure they’re not stuck?
Thanks guys
Thanks guys
7 blinks is power valves
nick5oh
Fixed it the same night boys. Cycled the servo motor and it was smooth. Checked over my wiring and had one tiny 2 wire plug with white wires unplugged. It was beside 2 other connectors under a rubber cover by the coolant bottle. It created the pv code and also my tach and fuel gauge were not working. Well that was what I noticed at least. Anyways thought I’d update to help others.
