1998 700 mountain max clutching
madmax98
newfoundland
hey guys new to the form and new to yamahas , currently working on a mountain max project . it was all set of for high elevation use with clutch kit primary and secondary gearing and jetting .
iv got the carbs done and sled is running great just looking for some direction on setting up the clutches , ill list the current set up best i can !
gearing 23/40
8CR-00 shift weight
AL or AC 10.3 RWET
white silver white primary spring
sec 80 deg 2-6
torque cam 43 deg
thats the best i can read it from the info i got with the machine , ran it tonight and rpms were up around 8800 wot, engagement seemed ok between 3500-4000 not to snappy !
any help be appreciate, and i picked up a complete stock secondary i can use aswell ..
The following is in the TY user set-ups
02 MM 700
8CR-00
4.5 first hole
3.6 tip
w-w-w primary
43 helix
Silver secondary
60 wrap on secondary
Set up for 0-3500 altitude in the new england mountains
An 02 MM7 came stock with 21/40, 70L chain.
