YamiSwami
Question..
Can I fit 2 2002 vipers in an enclosed 7 x 12 box trailer without any special maneuvering ? I have a line on a used (barn door style) enclosed trailer for 1800 in really good shape..
YamiSwami
reason im asking is because im using an suv to haul these ladies around and and the smaller the trailer the better for MPG..Figure if I pull one in straight on and to the left as far as I can go then back the other one in next to it, should be enough room to fit.
Any feedback on this? suggestions etc.
YamiSwami
seriously out of the 38 views no one has experience with a 7 x 12 fitting 2 vipers in it or even 2 sleds with 121 tracks? I guess I will go to the dealership and check it.. my initial assumption is that it will work with 1 sled driven straight in and the other backed in...
A couple of bucks
If it is 7 wide, that would be thee onnnllly way. Just measure your widest point on the front. Probably the skis. Then go from there.my initial assumption is that it will work with 1 sled driven straight in and the other backed in...
TobyRX1
I have a 6x12 enclosed and put 2 SRX's in. One forward and one backward.
Im not as strong as I used to be so its a pain in the BACK but have done it.
A couple of bucks
Weld/bolt a pocket onto the front of the trailer.Im not as strong as I used to be so its a pain in the BACK but have done it.
Drill powered boat winch.
https://m.youtube.com/watch?v=cll8-dXT4KY
i had an 6' x 20' in line 2 sled enclosed that would hold 3 136" sleds in it if i stacked them the way you are describing. it should work fine.
Draw it out on the garage floor or tape outline and park them in it and see how they fit.
