S Scarpino New member Joined Jan 8, 2018 Messages 6 Location Jackson Mi Jan 11, 2018 #1 I let the sled warm up for at least 10min but the carburetor closest to the primary clutch is not running as hot as the other two. Suggestions? roudyroy1 Active member Joined Jan 10, 2013 Messages 1,517 Location ontario GTA Jan 12, 2018 #2 do you mean cylinder or exhaust pipe? usually and indication of a cylinder misfire. i would check for spark and a fresh plug, then clean the carbs if the problem still exists. S Scarpino New member Joined Jan 8, 2018 Messages 6 Location Jackson Mi Jan 17, 2018 #3 Never mind I fixed the problem You must log in or register to reply here. Share: Facebook X (Twitter) Reddit Pinterest Tumblr WhatsApp Email Share Link
