Srx007
Hey all, having trouble understanding the tech section which is telling me that a stock 1990 phazer primary spring has 2 colors on it (gr-yel) while trying to find the spring in the tec sections I can only find springs that have 3 colors on them. Any clarification for the preload, spring rate, and total force would be great thanks. I believe the Father-in-laws primary spring is sacked as the engagement is only like 2200 (3500 stock). Deflection is good, primary parts are ok. Any info on the secondary spring would also be great Thx.
Srx007
SOOO..... the sled is a 1990 which is where I was referencing the tech section then I decided to look at the 1993 specs of which I don't think yammi changed much on those sleds in a couple years so I am going with those specs since the springs on the 93 have 3 colors and the secondary has 1. Again any info on the springs would be great thx.
you are on the right track for a good starting point. now it is just a matter of testing and making sure it worked.
