Anyone familiar with this secondary clutch? Erlandson Engineering
stewstang
Nebraska
just curious if any of you have run this clutch? im completely new to it all and was learning by turning wrenchs. Anyway what my main question is what/how do you know those white rollers are setup correctly? should the b able to spin freely, should they have a little resistance when you try to spin them or should they just be solid? There are allen bolts that control how those purple "ears" touch the white rollers. One allen head is an adjustment and the other is to lock the adjustment in place. (in my mind lol)
Thanks in advance!
Since that clutch is based off an arctic cat secondary and only run on Poo and Cat you might find information here hard to come by.
I think what is most important is that they are all the same and square to the helix ramps.
I sometimes run a Yamaha clutch machined for a cat helix which is similar to what you have. I like mine to just barely touch. Mine has no adjustment , just has to be machined correctly.
