It will cycle back to home position will it not? After I disconnected mine and started servo cycled to off position, idle it down to 900 to see if it cycles to open. But I would pull everything apart to inspect the cables for pull through etc. When you idle it down to 900 does servo activate? Cables routed properly, been out recently?
