2005 RX1 Won't Rev Up
nmquinn7
IL
I have a 2005 RX1 and it will not rev up. I rebuilt the carbs, put on new O-rings, needle and seats, readjusted, synchronized them, and still won't rev up unless you put on the choke a little bit and then it will rev up but it will backfire and sputter like it's out of time. I checked the timing chain, timing chain did not move. I checked the coils with an ohmeter, and bypassed the throttle switch. I have also done a compression test and that's good. I also checked the fuel pumps and put new fuel filters in.
Any help would really be appreciated. I have taken this apart numerous times and cannot figure out what's going on and how to fix it.
Please register on TY4stroke.com and post 4 stroke questions there. You will get more help on your question.
From my experiance your pilot jets are plugged and need to be cleaned thoroughly or replaced.
i thoroughly cleaned out the jets. I am starting to rule out carb issues and thinking it might be electrical?
