SLP Pipe set up
Brayjay
bc
Hey guys I have a set of slp pipes laying around and have decided to throw them on my 01 MM700. According to the slp website they say from 0 to 5000 feet to run a 45 pilot jet and 1 1\2 turns out on the fuel screw also 147.5 mains for 0 to -20 degrees. So stock pilot and screw setting. Would the 45 pilot be too lean? I run a 50 on my kids MM700 with bender pipes. Also says to use a Blue White Blue primary and stock Green spring. Anyone try this set up with slp pipes or have a different set up that works? I have the rivets that they recommend also. Thanks.
