what were the vipers HP rated at stock?
118-120 was the average for most stockers.
ViperTom
You should be right around 118-119 hp stock
125hp advertised I thought.
yamaholic22
about 118 h.p.
SRXSRULE
- May 2, 2003
Dont forgot to add 3hp for the Forced Snow Injestion! ===SRXSRULE===
yamaholic22
lol, have flatlanders had any problems with the air force, or just the mountain guys?
98srx6
I think anybody that rides in powder of any depth.
yamaholic22
yea that would make sense. Sounded like a good idea when it came out though...
thanks guys i thought it would have been more like 125-130
srx70024
I've seen around 123hp on the dyno.
DoktorC
I've seen 190 on the dyno (actually I haven't but hopefully I will shortly)..but I think he means stock lol
How can it only be 3hp more then an SXR...they're sooo much faster..
the hp numbers dont tell the story. the tourque # are so someone pls post those. learned the hard way with pu. had one with 6 cyl that pulled harder than the 305 i had in the truck after it. the hp #'s where about the same but the 6cyl had highr torque # than the eight did in the factory specs. was better on gas too.
98srx6
Maim said:the hp numbers dont tell the story. the tourque # are so someone pls post those. learned the hard way with pu. had one with 6 cyl that pulled harder than the 305 i had in the truck after it. the hp #'s where about the same but the 6cyl had highr torque # than the eight did in the factory specs. was better on gas too.
Dont let LazyBastard from www.rx1.info hear you say that...LOL
