Yamahasrx700
Any ideas on an 01 sxr 700 dropping only the spark on the pto cylinder. I already changed out the coil with a known good coil . Cdi?
drew24
magnets on the flywheel rusty? maybe rubbed through wire grounding out
A couple of bucks
Yamahasrx700
I took the coil pack off my SRX, same result. That eliminates the coil and plug cap. It is only dropping the PTO cyl intermittently.
A couple of bucks
Ground issue?? Do those coils have the brass bushings inside of the mounting hole.
Yamahasrx700
Yes they have the bushings.
