The lowdown on aftermarket proaction wheels with bearings...
snotwister
VIP Gold
Winnipesaukee
For those of you that are getting ready to replace the wheels in your proaction.
In my case, the 03 Viper, Ive been through the scene before but with partial wheel and some with just replacing the bearings..
There are 14 of them.
The two most forward on the top (the little guys, 3") use 6004
The two behind that on the top are 178mm aka 7 inchers, they use 6205, (25mm)
The four outside bogie rollers on the bottom are 130mm and they use the 6204 (if not the 6004) but they are COMPLETELY sealed with a honking plastic sleeve so the number is not visible
The two inner bogies on the shaft, on the bottom, just in front of the large 7's are 130mm as well but with the 6205 (25mm)
The most aft guide wheels are also 178mm but with the 6004 NOT a 6204.
Fitting a 6204 on the back axle will cause the skid to spread because the 6204, yes is it a 20mm, are 14mm thick as opposed to the ones you need which are 12mm (6004)
Please comment. I have part numbers if need be.
