Srx Steering Column on a MMax??
MountainMax
Churchill Falls,NL, Canada
hey guys, will an SRX steering colum put on a MMax fix my problem of the center carb hitting the colum? i have a boost bottle installed, and had to move my motor, shim it up amd move upmy breather to get it all to clear and it does so barley, I would get another shaft if it will fix it? also will a SRX colum need to be strenghthed up for my 2" riser block to work?
As a last resort I see SLP offers a chrome-moly steering stem with a
bend in it to clear the carbs. It ain't cheap but should fix your problem.
What kind of boost bottle you running? Hartman? Let us know how it
works when you get her dialed in, I been thinking about one.
www.startinglineproducts.com
I have a Hauck Boost Bottle, can't say forsure how it works cause I done a bunch of mods the same time, here is a pic of it, after i polished it.
